730 muffler studs and spacer removal
motorstuff
10-17-2007 19:01:39
One of the 4 muffler attachment studs is broken off and the other 3 are rusted and thin. The square cast iron spacer between the muffler and the cast iron radiador tank top is also damaged. I would like to replace the spacer and all 4 studs. Has anyone got some tips on how to do this without twisting off the studs in the radiator tank top?
Thanks
Mike
CLW
10-17-2007 21:29:04
 Re: 730 muffler studs and spacer removal in reply to motorstuff, 10-17-2007 19:01:39
[img]
I got these at auto-zone for about $8. They will cut the damaged or rusted nut off a stud in just a second. You can either clean and reuse the stud or it leaves room to double nut the stud and turn it out. PB Blaster helps on the stud first before you try to turn it out. I used it for just what you are needing to do.[/img]
CLW
10-17-2007 21:31:05
 Re: 730 muffler studs and spacer removal in reply to CLW, 10-17-2007 21:29:04
[img]third party image[/img]
Try picture again.
Markcycling
10-17-2007 20:54:49
This is what I have done-1. Soak the studs for as long as you can with a good penetrent.2 try to remove with an impact wrench-gently and back and forth. If they break-weld a washer to the stud-then weld a heavy nut to the washer and remove the stud with a impact wrench-This method has always workd for me-You will see it is almost magical-Good luck -Mark
motorstuff
10-18-2007 14:58:41
 Re: 730 muffler studs and spacer removal in reply to Markcycling, 10-17-2007 20:54:49
Thanks for responses. Does anyone think heating with a propane tourch would help?
Mike
