JD 2cyl combine engine
r4etired
10-17-2007 18:59:55
Neighbor has a Complete vertical 2cyl combine engine,it has a clutch and sheet metal enclosure. engine is loose but appears to need mag work. What is the value of something like this.
SMinWi
10-18-2007 14:21:17
 Re: JD 2cyl combine engine in reply to r4etired, 10-17-2007 18:59:55
If it has a hood that looks alot like a LA tractor, then its a LU power unit. Flat top hood will be a LUC or LUW. If the combine has a grain tank, its a LUC. If the combine is for bagging the grain, its a LUW. If its running $500 or more.
Mike M
10-18-2007 05:56:01
Not very much as I have listed a complete, original paint and all, one that runs and didn't even get any interest at $500 I'm in Ohio if your coming this way you can check it out. email should be open.
Walt in Jaxn Tn.
10-17-2007 21:25:35
If you are talking about a LUC engine, check to see what they are bringing to the left in "photo ads", also on E-bay. --Walt--
gtx1967jewison
10-21-2007 22:22:48
 Re: JD 2cyl combine engine in reply to Walt in Jaxn Tn., 10-17-2007 21:25:35
these are getting extremely hard to find & worth plenty in historical value at least & alot of CASH if u find someone who wants one. its the finding the right buyer thats the problem, as not many are into restoring (sadly) implements & combines YET!
