John Deere 60 Running troubles
DeereDiesel
10-16-2007 20:58:44
Hi I have a John deere 60 and it is runnning on only one cylinder and then all of a sudden it will fire on the other cylinder about once every 5 times the other cylinder has fired. Ive trided new spark plugs and new wires and that aint the problem. What could it be, the cap aint craked, it did get a little greese though the vent hole, but i wiped it down it that didn't fix it.What could it be. it all of a sudden started running kinda bad to really bad.I did a spark test to see if I had sprark on that cylinder and it does, but it was almost a constant spark Any suggestions would be great Thanks To Everyone!
F-I-T
10-17-2007 07:42:21
 Re: John Deere 60 Running troubles in reply to DeereDiesel, 10-16-2007 20:58:44
I would try to rule out the ignition failing on that one side first. I have an old neon-type, self powered timing light that is handy for these situations. Tape it to the hood, hook it to the suspect plug wire and run the engine. If the light keeps flashing when it begins to miss, you most likely have a fuel problem. If the light skips with the misfire, you know you are losing spark. On a "60" which has an on-board 12 volt source, any timing light will work, but these little neon types are great for anything from lawn mowers to hand-start, magneto powered tractors and the like. You can find them on eBay for under $10 most times.
If it hits consistently on one cylinder, then assume that that plug is good and swap them. If the good cylinder stays good, it"s not the plugs, at least this time. Stick with simple tests first.
Remember that on a "60" you have two halves on that carburetor and it is not uncommon to find one side with a clogged passage when idling. They pretty much run off of a common load side, so if you can load it down and it hits pretty even on both that is another way to prove the spark is good and the idle circuit on poor performing cylinder is bad. Just think it through.
Could you have a sticky valve? Any cough back or funny exhaust note when the poor cylinder acts up?
Frank
Mike M
10-17-2007 11:25:50
  Hey F-I-T where you been hiding ! in reply to F-I-T, 10-17-2007 07:42:21
Where you been hiding ? I hope you are ok.
F-I-T
10-17-2007 11:31:03
 Re: Hey F-I-T where you been hiding ! in reply to Mike M, 10-17-2007 11:25:50
I have been very, very busy. Won a contract that required me to add some people and that took me away from other things. Travelling alot. Left home on the 16th, and won't be home again until Nov. 9th. Doesn't leave much time to turn wrenches that's for sure. Business is good, just no slack time for me right now, but I figure that I can catch up on hobbies in the future.
Thanks for checking on me!
Frank
two cylinders saves gas
10-17-2007 15:52:26
 Re: Hey F-I-T where you been hiding ! in reply to F-I-T, 10-17-2007 11:31:03
Frank it's good to see ur still alive !!!
buickanddeere
10-18-2007 15:23:04
 Re: Hey F-I-T where you been hiding ! in reply to two cylinders saves gas, 10-17-2007 15:52:26
Welcome back Frank.
F-I-T
10-18-2007 17:04:46
 Re: Hey F-I-T where you been hiding ! in reply to buickanddeere, 10-18-2007 15:23:04
How's that leg?
buickanddeere
10-18-2007 19:14:18
 Re: Hey F-I-T where you been hiding ! in reply to F-I-T, 10-18-2007 17:04:46
Step-pop, step-crack,step-crunch, a few silent steps then step crack, step pop, step-crunch etc. Went back to work 3 weeks ago. Walking or standing on the concrete is a concern. Still all in all. Considering the location of the break, soft tissue damage, modern medicine etc.I'm just glad it works as well as it does considering. Years ago the recovery & use would not have been as optimistic.
F-I-T
10-19-2007 14:27:29
 Re: Hey F-I-T where you been hiding ! in reply to buickanddeere, 10-18-2007 19:14:18
Well, good to hear that you're getting along as well as you are. It could have had a very, very bad outcome.
Maark
10-17-2007 06:14:10
Try the easiest first. replace the plugs.
all 2cylinders
11-30-2007 16:02:39
 Re: John Deere 60 Running troubles in reply to Maark, 10-17-2007 06:14:10
He already said that he put new plugs in it. I would think that the side missing or not hitting , that the intake manifold gasket is bad. I had the same promblem with my 60. If the gasket is bad it will suck in air also until it is warm. What year is your 60. I have every year and model of 60 series.
