B throttle spring
patsdeere
10-16-2007 18:25:37
I am trying to compress the spring that goes under the throttle handle. I can't get it to compress and get the washers in (not to mention the darn cotter pin). Any suggestions?
CalJim
10-16-2007 21:25:55
 Re: B throttle spring in reply to patsdeere, 10-16-2007 18:25:37
Yes I remember going through this on my 44 BW. If I recall I had someone with a large flat blade screwdriver compressing the spring so I could insert the cotter pin. But the cotter pin rotating around against the washer created too much friction, lever was too stiff. Ended up installing a hardened pin just long enough to bear on half of the washer instead of going all the way through on both sides of the washer. CalJim
patsdeere
10-16-2007 21:34:15
 Re: B throttle spring in reply to CalJim, 10-16-2007 21:25:55
Isn't the pin just to prevent the throttle control shaft thing from coming up too high? If so, could you just drill a small hole on the shaft below the current hole so that the hole is just behind the panel? If there was a washer between the new hole with a pin and the cast iron would prevent horrible friction but would still prevent the rod from going up too high.
Sarah from Tulsa
10-16-2007 20:38:43
This is like the glass is half full/ no, Half empty? no, full, empty?
Sarah from Tulsa
10-16-2007 19:55:42
You guys have waaayyyyy to much time on your hands.
RobMD
10-16-2007 20:01:20
 Re: B throttle spring in reply to Sarah from Tulsa, 10-16-2007 19:55:42
What exactly is THAT supposed to mean?
Where is your contribution to this post? Oh, that's right, YOU DON'T HAVE ANY.
P Browning
10-16-2007 20:51:53
 Re: B throttle spring in reply to RobMD, 10-16-2007 20:01:20
Rob -- Don't waste your breath on Sarah -- she's probably still bitter and bent out of shape over a previous thread that went wrong for her. Just one of those ant bites you have to kind of ignore and hope it goes away. (PatB)
Sarah from Tulsa
10-16-2007 20:14:32
Well lets see the last two post proboly wasted 15min of their time, and it's obviously not that hard to figure out. Yet they are still trying to tell each other how to do it. You said it best RobMD, But you just summed up what everyone else said? SOOOO what did you contribute to the post????? ???
wilamayb
10-17-2007 14:03:18
 Re: B throttle spring in reply to Sarah from Tulsa, 10-16-2007 20:14:32
Well.... I guess he contributed more than you??? I get the impression that you may feel that perhaps you are more intelligent than the remainder of us? What would give you such and inclination?
davr191
10-16-2007 19:48:35
I've heard the old style valve spring compressors work great on these springs.
RobMD
10-16-2007 18:59:04
Do it like pat said, just put the pin in first and use a pry bar and a stop block to lift the whole thing to attach the handle.
P Browning
10-16-2007 18:46:26
It appears to me that you should install the cotter pin, washers and spring -- THEN bring the shaft up -- raise it sufficiently to install the throttle handle. This way, you can rig a method to pry (lift) to make the job do-able! (PatB)
patsdeere
10-16-2007 19:03:23
 Re: B throttle spring in reply to P Browning, 10-16-2007 18:46:26
I guess I am having one of those nights, but I can't figure out how that will work. The order has to be pin, washer, spring, washer. Some how the spring has to be compressed after the pin and bottom washer are put on since the pin won't go through the hole/column it passes through on the control panel. However, to get the top washer on the spring has to be compressed and put in as I push the shaft up since the top washer is bigger than the bottom of the throttle hand hole.
Here is the picture of the page:>Link
Parts>Link 9 to 15
Side note: What is part 18 on that page? I can't figure out what it is or what it was for.
Thanks.
P Browning
10-16-2007 19:48:39
 Re: B throttle spring in reply to patsdeere, 10-16-2007 19:03:23
Well -- My night hasn't been a stellar performance either -- let's try this again. Your question about Part 18 on page 50 of PC 330 is the bottom axis point (bracket) for your speed control shaft (9). It is up through this part that # 9 goes, and above this point that you find parts 10-12 & 15.
See also part # 17 on page 91. There you have the steering shaft bracket (17) -- the upper axis point for the speed control shaft, and it is in this part where your work is.
Begin with the speed control lever (14) along with its set screw (13) nearby, but not installed onto the speed control shaft (9). With the speed control shaft (9) brought up through the lower bracket (18), install then the cotter pin (15), small washer (10), spring (11), and the larger washer (12). So far, this "collection of parts" should be situated just under the steering shaft bracket (page 91-17), and you have the speed control lever with set screw ready -- also a wrench for the set screw!
Compression job: The work now is to get under the speed control shaft with a suitable means to lift it up through the tapered opening in the steering shaft bracket -- far enough to install the speed control lever, and tighten the set screw into its prescribed hole in the speed control shaft, and then release the "lift" tension. Presto! It's done! This would be my plan. (PatB)
patsdeere
10-16-2007 20:20:48
 Re: B throttle spring in reply to P Browning, 10-16-2007 19:48:39
Thank makes sense. However, as the rod comes up and you put the pin in (then the washer and spring) the rod top is above/about the height of where the throttle handle is. What I can't figure out is how to get the washer on since it is larger than the bottom of the tapered throttle shaft hole.
I forgot to mention it is an electric start. It looks like the panel in this pic: Link
Lee B
10-17-2007 02:01:43
 Re: B throttle spring in reply to patsdeere, 10-16-2007 20:20:48
Is there any way to remove the mounting tube that is not pictured such as to create a much longer working zone?
14 must be removed for this method. 18 is attached to the mounting tube and that whole assembly is removed and then lowered onto 9, 10, 11, and 12 just waiting to be compressed by 18 and finally 14 when the mounting tube is re-attached to the tractor. Kind of the long way home, but it's the only way isn't it?
P Browning
10-16-2007 20:48:25
Ah -- I was fearful of that! Well my friend, I reckon that one just jumped outside my comfort zone -- I haven't been there and done that one! I tried.
We need a "long hood" guy or gal to jump in here with some help. (PatB)
