Gauge Connection on '40 JD A
Dean Lydey
10-16-2007 18:14:48
This may be the silliest question asked about a restoration. I'm putting my A back together and I've forgotten where the connection for the oil pressure and temperature are found on the tractor. I got my new gauges in today and they nicely fit into the freshly painted dash but it occurs to me that in all of my pictures I didn't record where these get plumbed into the tractor. The temp comes with a 4' lead and fitting and the oil gage has simply a male fitting on back. I hope it's obvious when I get to the farm this weekend. In the event it isn't, can anyone tell this green horn where to look.
Thanks,
Dean
James Howell
10-17-2007 10:06:18
 Re: Gauge Connection on '40 JD A in reply to Dean Lydey, 10-16-2007 18:14:48
Lee B is correct. The temperature sender is mounted into the back of the upper radiator pipe.
You might consider draining the water from the motor before installing the sending unit. The oil gauge line connects to the rear of the governor case, from a hole pointing straight back. I recently replaced the copper line that goes in between the gauge and the governor case on my 46A.
It required the JD original 90 degree elbows to make the connection.
Hope this helps.
Dean Lydey
10-17-2007 05:04:26
Thanks for the help.
Dean
Lee B
10-17-2007 02:21:41
I'm thinking the temp sender is mounted into the upper radiator pipe as it leaves the block?
And I KNOW that the oil gauge is supposed to get it's oil from the rear of the governor case, from a hole pointing straight back as if one could just screw the gauge in there and read it. The hole will be 1/8" pipe thread which may look just like a 3/8" fine threaded bolt hole until you realize that there were no fine threads made on your tractor. Hope you didn't already use it for the battery ground strap...
Mine has a fine copper line that goes in between the 1/8" pipe fitting on the gauge and the same sized hole in the governor case. So did yours, it's around there somewhere probably. It might involve a 90 degree elbow too.
