55H or 555H plow? Whats the difference?
Daniel Hartzfel
10-16-2007 15:45:07
I bought a plow this weekend and I am not sure if it is a 55 H or 555H plow. It has 3-14" bottoms if that helps. Thanks for any help!!
Paul_IN
10-16-2007 17:28:19
 Re: 55H or 555H plow? Whats the difference? in reply to Daniel Hartzfeld, 10-16-2007 15:45:07
There are some easy clues. The 55 is older and it will have spoked wheels for the land and furrow wheels. The 555 will have tapered roller bearing hubs with pressed steel disk wheels. The 55 has solid moldboard standards and the plow is protected from getting bent from obstructions by a spring release hitch or a tractor clutch release. The 555 will have trip back standards so each moldboard is individually able to trip if an obstruction is hit while the plow remains hitched to the tractor. I believe the 55 was made starting around 1940 and up to 1956. The 555 went from 1956 to 1961 approximately.
