is there a fuse in wiring harness?
730virgil
10-16-2007 15:30:51
as tall kid was trying to start 730 diesel electric start it just quit. starter was spinning engine over when starter quit. is there a fuse to switch? where is it? it doesn't act like batteries went dead as starter didn't drag down.
K.W. in Tx
10-16-2007 22:07:57
 Re: is there a fuse in wiring harness? in reply to 730virgil, 10-16-2007 15:30:51
I would take a test light first and make sure you got power from the battery to the starter. If good then check and make sure one wire on the key switch has power at all times. If good check wire from switch to the starter solenoid while someone turns the switch to the start position. If good its probably solenoid or starter motor if everything has power. Might also be the ground wire on battery. Also check connections on the starter and solenoid for looseness and sometimes Ive seen regulators cause problems. And it could be the key switch if solenoid wire gets no power(but would be rare). Thats all I know to do when I have a problem like that. Good Luck
544
10-16-2007 20:52:38
there is no fuse in a wiring harness i just replaced mine been there done that what is wrong with your machine i don't know might be wiring harness but there is no fuse in it good luck
