46 B REMOVING OIL FILTER ASSEMBLY
TIMAR
10-15-2007 18:24:19
How do you get the whole assembly out of the engine case? Thought I would ask befor I break something.
Mike M
10-16-2007 05:23:54
 Re: 46 B REMOVING OIL FILTER ASSEMBLY in reply to TIMAR, 10-15-2007 18:24:19
Well it goes something like this, not nessesarily
in this order.
Unhook all the lines on the inside,there is a piece up in where the filter goes that has a plate and a stem. You need to remove this. A wire from a bucket handle or some rod bent in a U with small L shaped hooks on the ends.You will feel up on that stem 2 holes to stick this tool into then take a hammer or something ? and knock down on that U thus pulling that stem out. Then you can get up in there and remove the 3 bolts holding the cast iron relief valve top part from the steel can in the case. I would not recommend removing the steel can unless you need another or are switching it into a tractor that needs one. If you are leaving it alone just make sure the top where the gasket goes is as flat as you can get it. alot of these get pulled down in from overtightening of the filter cap. If you do need to pop that can out get some round flat tight fitting steel piece put it in there for support and then drive it out which is UP into the crankcase area. To reinstall I draw them down in with all thread and a plate.
TIMAR
10-16-2007 09:59:43
 Re: 46 B REMOVING OIL FILTER ASSEMBLY in reply to Mike M, 10-16-2007 05:23:54
Thanks. Parting out the tractor, so won't need to reinstall it.
Mike M
10-16-2007 10:34:51
 Re: 46 B REMOVING OIL FILTER ASSEMBLY in reply to TIMAR, 10-16-2007 09:59:43
I that case I would pull it all out cause you never know when you will need one. I think that same can may fit all the tractors too. But not the H model.
