60 plug gap
bobidan
10-15-2007 18:16:16
I just purchased a 1956 model 60 with a mounted cultivator..... very nice original tractor i put new plugs in it autolite 386's new points and a high voltage coil should i have raised the plug gap from .030 with the higher voltage coil
John T
10-15-2007 19:52:44
 Re: 60 plug gap in reply to bobidan, 10-15-2007 18:16:16
I dont forsee any problem with runing a 0.030 plug gap but for the record that so called "High Voltage Coil" wont fire at any higher voltage then the stock coil would have at the same gap and conditions UP UNTIL THE POINT THE GAP WERE INCREASED SO WIDE THE STOCK COIL COULDNT ACHIECE A HIGH ENOUGH VOLTAGE TO ARC CURRENT ACROSS THE GAP but the High Voltage Coil could..... .. To get greater performance its when you couple a high energy high voltage coil with an electronic ignition switch and run a much wider plug gap like 0.035 to 0.050 or so for a wider hotter spark that really gets you going.
Just cuz that high voltage coil has the capability to achieve a higher voltage dont mean it does cuz the voltage at which a plug fires is a function of the plug gap distance and the medium (fuel and compression) in which it fires. If a high voltage coil has a lower then stock coil primary winding resistance the points will burn up sooner but thats where an electronic switch has an advantage cuz it can handle higher current plus switch it more positively versus bouncing ringing mechanical points and the paralell condensor.
John T
bobidan
10-16-2007 13:29:25
 Re: 60 plug gap in reply to John T, 10-15-2007 19:52:44
thanks for the reply i was reading a post about electronic ignitions and it got me to wondering about the plug gap with a higher voltage coil
