B cylinder crack. possible sleeving
435freak
10-15-2007 17:38:56
My 41B has a crack in the bottom of the lt cylinder skirt up to the block. Does this hurt anything. Should I get it fixed before rebuilding? If I need to get the cylinder sleeved who does this? Do I need the oil scraper ring?
TIMAR
10-16-2007 10:01:13
 Re: B cylinder crack. possible sleeving in reply to 435freak, 10-15-2007 17:38:56
I have a excellent standard bore block from a 1946 if it would work for you.
Mike M
10-16-2007 05:07:59
Do some pricing first. There are still many NOS blocks for that year sitting around too.
B_Bob
10-15-2007 19:58:24
I have a 50B with cracks in both cylinders. A guy in Wyoming gave me a price of $800 to do both. He is highly recommended, however..... .I'm still shopping for a used block.
jd b puller
10-15-2007 18:42:49
In order.
ouch. Yes. Yes, depends where you are located. yes.
The bore is small enough many auto shops should be able to bore it out for you and stick a sleeve in there.
435freak
10-16-2007 15:38:27
 Re: B cylinder crack. possible sleeving in reply to jd b puller, 10-15-2007 18:42:49
Ok jd b puller I have another question. As about 1/3 of the oil scraper ring on the heinrick aluminum pistons I purchased sticks out below the skirt, if I resleeve can I easily insert a longer one to accomidate this ring? The stock piston comes to within 1/8" but does not come out. Are the later (42-46) skirts any longer? I have the correct piston according to the manufacturer.
Earl - IL
10-16-2007 18:36:31
 Re: B cylinder crack. possible sleeving in reply to 435freak, 10-16-2007 15:38:27
I move the oil ring to the groove above the pin. This solves that problem plus it leave a film of oil on the piston skirt where it needs to be.Depend on the piston sometimes I drill the piston groove for drain back. Any questions email me. Earl
jd b puller
10-16-2007 16:02:39
You"ve got mail...
