jd620 trouble in reverse
bbaro
10-15-2007 12:33:29
will try to keep this as short as pos. with tractor in reverse and clutch engaged no problem, now if i disengage and stop once in a while when i am engaging the clutch still in reverse the tractor wont move and i get a grinding noise, i cant pinpoint the noise though, clutch drum or trans. i have used the tractor a little it does not pop out of any gears and there are no strange noises except the grinding noise in reverse once in while. thanks for any info.
RobMD
10-15-2007 13:05:36
 Re: jd620 trouble in reverse in reply to bbaro, 10-15-2007 12:33:29
sounds to me like a shift rail fork or something on the reverse idler shaft is coming loose. The only realistic way to see is to pull the shift quadrant off.
