Hi all. First, let me warn you, I'm no mechanic, but I fake one under a shade tree every weekend...First off, I have a 1958 420 that has `jumpy` hydraulics. That is, when I lift the 3 pt hitch, once it is stationary, the implement `bounces` up and down erratically. It's not a big bounce, the implement pretty much stays in the same place but it bobs up and down about an inch or so. Any ideas on this? Secondly, I've had to repair the back end of the tractor. (Ok, I don't know the names of these parts ... so bear with me!) In the rear of the tractor there is a rod that with gears that pick up the arms on the 3-pt hitch. Well, to my surprise, I was able to get all of the 3 pt machinery stripped apart and put back together and it even works! (It was `jumpy` before I did this). But it's not all roses. I have a leak coming out of the left-arm of the three point hitch. It's the side that has two `arms` on it. I'm missing the larger seal on that side. Can anyone give me a part no. on that seal? Also, can anyone tell me the real name for that big rod in the rear of the tractor that works the 3 pt hitch? Thanks a bunch! Broken in Mississippi
