50 throttle control
Tom/Idaho
10-15-2007 05:35:42
I have the adjusting bolt as tight as it will go and there is still play in the throttle handle. I removed the assembly from the tractor but how do I get it apart to change the fiber washers? I have a 60 parts book, but this one looks different. Any help will be appreciated. Thanks, Tom/Idaho
Carl NY
10-15-2007 10:15:26
 Re: 50 throttle control in reply to Tom/Idaho, 10-15-2007 05:35:42
Tom. Back the bolt all the way out so the speed control arm will seperate from the speed control lever. Once the bolt is removed some force may be required to pry apart the asembly. There is a spacer & dowel pin that will probably be rusted in. The fiber washers are no longer available from Deere. The speed control plate has the material bonded on to it now so you can purchase a new speed control plate or improvise some material to to replace the the friction discs. It is an easy fix.
55 50
10-15-2007 08:03:21
Quite easy. Take out the adjusting bolt that you mentioned. Depending on the serial number of the tractor, you will find three different assemblies. The latest change is part number AA 6077 R. It is the speed control plate WITH friction facings attached. It should still be available from JD but I didn"t look up availability.
I have both 50 and 60 Parts Catalogs and the assembly looks identical in those two Catalogs. If your looks different, possibly someone jury rigged a "new design"?
