JD 224 square hay baler
haybaler
10-12-2007 21:04:28
The wire rapes around the shaft above the twisters. Any ideals ?
Tx Jim
10-13-2007 04:25:51
 Re: JD 224 square hay baler in reply to 1936, 10-12-2007 21:04:28
Twister hooks may be retarded back to the RH direction one or two teeth to aid wire to slip from around twister shafts after tyiing cycle has been completed. Pouring oil on boxes of wire can help as some brands of wire don't have enough lubrication. Look at twister shafts for a groove spiraled above twister hook. If it is noticable,one can rotate shaft 180 degrees if shaft only has one groove,after rotation loosen twister hook and rotate it 180. If shaft has two grooves then it needs replaced.HTH,Tx Jim
baler46
10-12-2007 21:09:52
 Re: JD 224 square hay baler in reply to haybaler, 10-12-2007 21:04:28
