6620 hydrostat
barneyfife
10-12-2007 20:16:47
I have a friend who thinks has hydro is out combine moves then stalls out. jacked the rear wheels off the ground and turned on 4 wheel drive with transmisson in nuetral wheels only turn if u start them and you can stop them buy hand, what do you check and how hard is it to change out thanks
Roger in Iowa
10-12-2007 20:26:30
 Re: 6620 hydrostat in reply to barneyfife, 10-12-2007 20:16:47
You cannot prove a thing with the transmission in neutral.
Put it in high gear and see what the rear wheels will do.
Pressure should be about 5000 psi with all stalled. Don't do it long.
Does it work in reverse? If so, switch relief valves and see if it now works in forward. Might be a failed relief valve.
Roger in Iowa
