70 Power steering adjustment
Ranchingelec
10-11-2007 06:06:19
Hello there. The power steering will work great when I turn the wheel to the right. but when I turn it back to the left power steering will not assist me. Where do I adjust this. To me it seems that the actuator valve needs adjusting. What do you think?
Ken in MN
10-11-2007 17:14:11
 Re: 70 Power steering adjustment in reply to Ranchingelec, 10-11-2007 06:06:19
The steering valve needs to be "centered". The nose cone will have to be removed, then loosen the bolts on the valve slightly, and tap it toward the rear of the tractor. In my experience, it only needed to move so little that you could not visually tell that it did move. Tap it once, then try turning the wheel, repeat until you have it. If you go too far, you will have no assist to the right.
