1020 added loader now slow 3pt.
petebeef
10-10-2007 17:25:44
I took a loader off a 1010 jd. I put it on a 1020. I put the power line on the right side below the foot rest behind the brakes,I think it is called a pressure control valve. the return line I removed the plug on the right side of the rockshaft housing.The 3pt. now goes up real real slow hardly moving at all, but if I use either of the handles on the loader the 3pt. goes up like it should and the loader works like it should.before I put on the loader the 3pt. chattered a little bit but it came up pretty good. The power steering still works like it should.
Bob
10-10-2007 17:31:39
 Re: 1020 added loader now slow 3pt. in reply to petebeef, 10-10-2007 17:25:44
The 1010 has a gear pump, and an "open center" system.
The 1020 has a radial piston pump, and a "closed center" system.
If the loader valve was correct for the 1010, it is the WRONG type of valve for the 1020.
Depending upon who made the valve, there may be a kit to convert it to "closed center". Otherwise, you will need to get a "closed center" valve to replace it.
petebeef
10-11-2007 15:18:01
 Re: 1020 added loader now slow 3pt. in reply to Bob, 10-10-2007 17:31:39
Bob thank you very much
grwrench
10-11-2007 17:17:53
 Re: 1020 added loader now slow 3pt. in reply to petebeef, 10-11-2007 15:18:01
hello, the control valve has to be closed center for a 1020, also you need to hook up a return to the filter cover so your loader will work properly.
