Hydraulic cylinder information needed
K.W. in Tx
10-10-2007 11:05:27
Can anyone tell me how to get the lift cylinder rods/piston out of a 175 loader on a JD 2150? It has a outer snap-ring, took it off and cant get the piece that holds the wiper and o-rings out. So how do you get them out? Jerk them apart? I havent worked on any JD loaders before so help is appreciated.KW
Tx Jim
10-11-2007 03:32:44
 Re: Hydraulic cylinder information needed in reply to MTC, 10-10-2007 11:05:27
KW,Kevin told you the correct way to do it. Jim
Kevin Schmidt
10-10-2007 11:56:12
 Re: Hydraulic cylinder information needed in reply to K.W. in Tx, 10-10-2007 11:05:27
Hi,
I don"t know for sure on a 175 loader, but on other JD cylinders, you take off the outer snap ring, then actually push the end of the cylinder down into the casing. There will be another snap ring that looks like a wire, take that one out and you should be able to pull it right apart.
Good luck
K.W. in Tx
10-10-2007 12:26:14
 Re: Hydraulic cylinder information needed in reply to Kevin Schmidt, 10-10-2007 11:56:12
That would make sense to me, I just want to get a little more info before I try so I dont mess anything up to bad!!! Thanks alot
