JD 40 Carb
Alan Whitaker
10-10-2007 07:57:35
I've got a 1952 JD 40 that has a TSX 688 carburetor.
This looks to be a carb for a 420. I've not been able to get it to run to my satisfaction. Do I need to change the carb? What carb is recommended?
Thanks!
MLD
10-12-2007 07:44:27
 Re: JD 40 Carb in reply to Alan Whitaker, 10-10-2007 07:57:35
I would suspect if its a 420 carb on a 40 its getting to much fuel. Remember the 40 was equal to the 320, a 420 is bigger. If its running rich I would say the carb is jetted to high for your tractor.
jCarroll
10-10-2007 11:30:44
www.jd40.com
says a TSX 530
Alan Whitaker
10-10-2007 15:33:26
 Re: JD 40 Carb in reply to jCarroll, 10-10-2007 11:30:44
So what is the difference between the two? Do I need to change?
Mike M
10-12-2007 05:41:42
 Re: JD 40 Carb in reply to Alan Whitaker, 10-10-2007 15:33:26
I would really tend to doubt the different carb. numbers are really that much different. As long as they look similar and have similar size of openings and have adjustable load and idle circuits it should run. The one you have may be plugged up somewhere ? but no 2 are really going to perform identical due to wear and even could have been drilled a little different from new.
And then there is always the chance the tractor has another problem but makeing you think it has a carb. problem when it doesn't. This is where having another tractor around to swap parts off of can be a big help.
