50 amp gauge
Rich Va
10-10-2007 04:38:25
Any way of checking to see if my generator is charging by using a dc test light. My amp gauge quit working when the battery got reversed. After I unstuck the points in the regulator and sent the generator to the shop and polorized no read out on amp gauge. I used the tractor several times and it cranks and runs ok like battery is at full charge.thanks
Gerald J.
10-10-2007 08:28:42
 Re: 50 amp gauge in reply to Rich Va, 10-10-2007 04:38:25
A test light won't tell you much. The sometimes factory generator lights didn't tell much either.
Go spend the $8 at your local car parts emporium for a new ammeter...
Gerald J.
Rich Va
10-10-2007 08:58:44
 Re: 50 amp gauge in reply to Gerald J., 10-10-2007 08:28:42
I guess I could rig up an elcheapo before I spend the bucks for the JD gauge. Then I will know.
