So I'm a Farmall guy.I helped out an old timer up the road who had a spare part floating around in the inlet of his carb on his 420. It was the relief valve/plate or whatever it's called from his choke plate. I replaced the spring, which I assume has been digested by now, that holds it in place and got his carb fixed. I got home the other night and the tractor is parked in my yard and he says it doesn't run right. Small wonder, sez I, looking at the plug wire resting lightly on the dist cap, and the condition of the contacts. So it will need some ignition work. One of the cyliders is pretty cruddy looking. There's so far I'm willing to go on this, but figure I'll run a compression check between the two cyliders and clean up his ignition. Would even spring for a cap, rotor, points, condensor, plugs and wires as a good deed. Here's the embarassing part. What's the firing order, looking at the top of the cap? And which cylinder is which? I can search and find point gap, but if anybody has that handy, that would be welcome information. Location of a timing mark would be helpful, too, I suppose. I'd got a manual but this is (I hope ) a one-time good deed. Also, any thoughts on whether that tension spring on the choke plate might be jamming a valve open? I tend to think not. It's real small and I'm thinking (hoping) it's been burned up and and/or blown through. Or is that wishful thinking? Thanks for any help you can offer!
