JD 2750 -I NEED HELP!
LWS
10-08-2007 17:37:39
On my 83 2750, I am getting engine oil in the water. I have replaced the engine oil cooler and it still gets oil in the radiator. Some have said this could be a JD problem with the engine block cracking in a oil passage. It does not get any water in the crankcase. Could the head or gasket cause this problem? Any help appreciated.
Jim Presley
10-08-2007 19:57:08
 Re: JD 2750 -I NEED HELP! in reply to LWS, 10-08-2007 17:37:39
More than likely it is the head gasket. Other things such as a cracked head could be the case, but would take an overheat condition or loss of oil condition that you would be aware of when it happened (overheat, burnt smell etc.). Either way, you will need to pull the head to find out. Have the head checked at a shop for cracks when it is off and take a good look at the gasket when it is pulled. Probably a leak from one of the oil passageways that is allowing oil to flow into a water passage. 90% of the time it has to do with the head gasket if you are getting oil in the water, but no water in the oil. A crack in the block would also put water in the oil.
Jim P
