John Deere 4230
630man
10-08-2007 17:22:59
I have a 4230 John Deere and tonite my front work light quit working after about 30 minutes. then i shut the switch off for about 10 minutes and tried the lights again and then they came on for 45 seconds and went off. does any body have any idea what my problem might be. any help would be great.
Tx Jim
10-09-2007 04:25:06
 Re: John Deere 4230 in reply to Darwincam, 10-08-2007 17:22:59
There are also relays that control lights that could be giving problems. If I remember correctly they're under the dash. Remove panel under switches to access. Tx Jim
Bob
10-09-2007 08:22:14
 Re: John Deere 4230 in reply to Tx Jim, 10-09-2007 04:25:06
The "40" series have headlamp relays, the "30" series DO NOT.
Tx Jim
10-10-2007 04:53:08
 Re: John Deere 4230 in reply to Bob, 10-09-2007 08:22:14
BOB,Thanks for correction. I don't have a tech manual and it's been over 20 yrs since I worked for a JD dealer.Tx Jim
Bob
10-08-2007 19:13:29
 Re: John Deere 4230 in reply to 630man, 10-08-2007 17:22:59
A circuit breaker is tripping because of overload, or cause there's a poor connection at the breaker, and it's heating up, which is COMMON on these tractors.
The breakers are under the LH cover on the steering pedestal.
Tighten ALL the nuts on the breakers, replace any burnt breakers and repair the "buss bar" or other terminals and insulators as needed.
You can easily tell which breaker is tripping with a test light.
If no problems there, there must be s short in the wiring or one of the lights.
Post back, and let us know what you find!
df
10-08-2007 17:43:47
My first guess would be to remove the dash cowl. On the left side just behind the PTO lever there is a circit breaker box w/ a plastic cover. Remove the cover and check to see if all of the 10mm taps are tight in the circut breakers. We have a 4440 that did the same thing on the ignition switch. Hope this helps.
