430 PTO problem
Woody D.
10-08-2007 16:09:39
I recently purcased a 1959 430 john Deere to restore.. This is my first. Am learning as i go. The PTO free spins when tractor is running but will not work when engaging the PTO control.. Can anyone give me any pointers on where to start first.. Thanks.
cole in mo.
10-08-2007 17:38:48
 Re: 430 PTO problem in reply to Woody D., 10-08-2007 16:09:39
If it has live power the two pto gears could be stripped of teeth.
Woody D.
10-10-2007 16:53:21
 Re: 430 PTO problem in reply to cole in mo., 10-08-2007 17:38:48
Thanks Cole & Larry, I thought that would be best place to start.. A friend of mine said the pto control lever could be worn causing it not to engage, so i will pull the shaft first and look at it.Thanks for your advise,,,
Larry Baker
10-08-2007 17:33:04
the drifting doesnt worry me but as for it not working i'd take the three bolts out and remove the shaft and look to see if the color is stripped.With it out you can see the end of the shaft of the trans and observe from there.
after that you can tell whats your next move.
