JD 40 Standard - multiple issues
jd b puller
10-07-2007 19:26:04
Guys, I had posted this last week, but didn't get any replies. Still looking at the tractor, can anyone help?
Hey guys, I went and looked at a JD 40 Standard today. Here's the Good stuff.
1. Hood/dash are near perfect (just rusty)
2. Adjustable wide front, spin out rear wheels
3. nose, pretty good. 4. Started right up. 5. Has the front weight M2543T
6. Has rear wheel weights
Now here's the bad stuff...
1. Engine smokes the whole time it runs (oil smoke)
2. Front wheel hubs are in need of help (sloppy)
3. Needs brakes (grinds hard on RH side, not much brake on LH side)
4. Steering real sloppy
5. Gear shift is REALLY sloppy as well. Very hard to find gears.
Questions: I really don't mess with these Dubuque tractors that much. How complicated is the shifter issue, the brake issue? Engine - who knows, I did notice that it was holding 10PSI oil pressure while cranking, and essentially pegged the gauge at 30+ while running.
Any help is appreciated, including what this thing is worth.
Thanks,
George S. in the real NY
10-10-2007 02:40:54
 Re: JD 40 Standard - multiple issues in reply to jd b puller, 10-07-2007 19:26:04
That 40 is over priced. With bad engine and other issues, I would say $500 to 750 is a fair price. Too many important mechanical problems that will eat up dollars. 40S is a nice tractor but that one needs a lot of help.
Ray
10-08-2007 17:38:11
You can buy a good one for $3500-$4000,unless you get that one for free it's not worth it.
RobMD
10-08-2007 08:13:20
Disc brakes are a pain in the arse.
Mike M
10-08-2007 06:50:15
Buy the one with the best sheetmetal you can find the rest is easy to replace. Those problems are going to be found on most any other you find too. It all depends on the price. Just get it cheap enough so you can afford to fix it. Sounds like a nice little project.
jCarroll
10-08-2007 06:29:53
A couple more things to look at:
a) Does it have the generator - or converted to an alternator
b)Raise the TOM - shut it off, and see if it settles any in 15 minutes. If yes, you've got an overhaul job on the rear end.
c) One piece grill or 2 piece?
It's worth $1721.
johndeeregene
10-07-2007 20:34:43
well you know what has to be done to the motor, the brakes you will have to take off the axle housings, they are right next to the center section, the steering the pins are wore bad, in the steering section in the front pedistal. i think you can still get them from john deere, have replaced them before. the gear shifter itself is more then likely wore out, you can get a new one from john deere also there is a pin that get real loose that holds the shifter in an pivots on, replace both, both from john deere an you might as well get the boot also.
jd b puller
10-09-2007 19:41:51
 Re: JD 40 Standard - multiple issues in reply to johndeeregene, 10-07-2007 20:34:43
Guys, thanks for all the replies. I forgot to set the e-mail notification and didn"t realize you all had contributed...
He"s asking $1700 for it. Not sure it"s worth it from the replies. Pretty tired old tractor..
