3020 won't go into gear
Arturo Balderra
10-07-2007 15:39:04
This John Deere 3020 tractor had been setting idle for about a year. I Finally got it started and now it won't go into gear. I tried every position and still no go. I tried adjusting the clutch pedal and it didn't do any good. I only adjusted the small nut up and down but I did not adjust the big one with the cotter pin. Any help on what else I could do or check would be greatly appreciated. Thank you and have a good one.
RobMD
10-07-2007 20:51:19
 Re: 3020 won't go into gear in reply to Arturo Balderrama, 10-07-2007 15:39:04
YOUR clutch is STUCK. Your clutch disk is STUCK TO THE FLYWHEEL, even if you have the clutch pedal all the ay in. you may be able to break the clutch free by pulling it around in gear with the engine off and working the clutch pedal.
2cylfarmer
10-07-2007 17:53:50
Does the shifter move into the gears? do you hear gears grinding when you let out on the clutch?
Arturo Balderrama
10-07-2007 19:40:44
 Re: 3020 won't go into gear in reply to 2cylfarmer, 10-07-2007 17:53:50
yes i hear a grinding sound at times. At other times it won't do anything. It goes from park to neutral but not to forward or reverse.
R. John Johnson
10-07-2007 23:09:29
 Re: 3020 won't go into gear in reply to Arturo Balderrama, 10-07-2007 19:40:44
Arturo
Is this a power shift or a syncro range transmission? The way you say from park to neutral but not forward or reverse sounds like a power shift.
John
10-07-2007 15:50:26
I HAVE A 3020 I LOVE IT WE HAD TO REPLACE GAS TANK THE WHOLE WIRING HARNESS ALL FILTERS FLUIDS BREAKS AND TEMP GAUGE HYDRAULIC FLUID AND THE GEARS MY BE FROZE UP RUSTED OR COULD BE THE FORKS IN THE TRANSMISSION
