New JD B
Ben Rauls
10-07-2007 14:26:32
Just got my new tractor home, by far my favorite, out of my Farmall M and my oliver 88 diesel. Its a 1944 B, runs pretty good. What do you recomend for spark plugs? How many friction dicks are there supposed t be in the clucth? Theres one in there now but the adjusting nutsare in quite a ways, the holes for the cotter pin are above the nuts. Just wanted to share with everyone.
Ben
Someones gonna say it
10-11-2007 18:55:54
 Re: New JD B in reply to Ben Rauls, 10-07-2007 14:26:32
Only one friction dick here. Sometimes it gets too much friction. Then it hurts!
Trent M
10-09-2007 08:35:52
Just wanted to say that's a nice looking B!!
CalJim
10-07-2007 22:48:52
On a 44 you can only install the drive disk on one way, look inside the disk, you will see what looks like a rivet head. Then look at the splines on the crank, you will see one that looks like it is broken off at the end. When you install the disk line up the rivet with the short spline. CalJim
P Browning
10-08-2007 06:45:42
 Re: New JD B in reply to CalJim, 10-07-2007 22:48:52
Hi Cal -- Thanks for coming in there to help what appears to be a fellow new to John Deeres. I am not fully familiar with the clutch drive disk interface to the crankshaft -- but I also felt a comment made earlier was too brief.
The main thrust of my post still holds -- get the manuals before delving in for the first time! This forum is great but you cannot take all comments as golden -- because people are tired, or in a hurry and a critical detail can easily be left out. Later! (PatB)
P Browning
10-07-2007 20:28:49
Ben -- WAIT! Wait until you have the manuals for your tractor before you tear into it!
Call 800-522-7448 with model & serial number in hand, and you will be seeking two manuals, Operator's Manual and a Parts Catalog.
Go to (www)dot(retiredtractors)dot(com) for your SM2004 Service Manual. Be careful! DO NOT BUY SM2000! You won't need it.
As for "marking", Pappy is telling you that the position of the clutch driving disk (the heavy piece) in relation to the shaft is CRITICAL and you should place index marks on each so as to ensure they go back the same as you found them! To go off half-cocked and start taking things apart is not wise without guidance! Wait for the manuals. You will be glad you did! (PatB)
BC_2006
10-08-2007 18:26:16
 Re: New JD B in reply to P Browning, 10-07-2007 20:28:49
Good advice on the manuals...all three are available from Deere (assuming that is the phone number for it - also techpubs.deere.com (if you know the manual numbers you need, like SM2004) - SM2004 is a must have...
Pappy
10-07-2007 19:02:48
For spark plugs, I like the Autolite 3116 or 388.
You should have two friction discs. One is visible and the other behind the clutch driver disc. If you remove the clutch driver to get to the interior disc, be sure to mark it and replace it in the exact same position on the splined shaft.
