JD 310C backhoe slow to engage forward
wildfire
10-07-2007 12:17:56
I'm out on a remote ranch in AZ, so taking this girl to a repair facility is no easy or affordable task. So ..... it's a 1987 310C loader/backhoe w/7000 hrs. She used to engage in forward as soon as the forward/neutral/reverse lever was put in forward position (1st gear). Now there,s quite a lag between placing the lever in forward and actually feeling the machine engage and after it warms up you need to increase rpm to get it to engage. While in forward and facing up hill she'd always hold in position, know she'll slowly creep backward. In order to keep it from creeping backward you have to increase RPM. I'm pretty good at repairs but am not sure about this one. If any one has any ideas I'd sure be greatfull to hear them.
Tx Jim
10-12-2007 04:12:38
 Re: JD 310C backhoe slow to engage forward in reply to CharlieMc, 10-07-2007 12:17:56
wildfire have you done the "simple things" first such as changing hyd filters and cleaning sump screen? Tx Jim
Jonathan in MA
10-07-2007 17:15:53
 Re: JD 310C backhoe slow to engage forward in reply to wildfire, 10-07-2007 12:17:56
Quick and easy check--- remove dipstick for the reverser and smell the oil... if it smells burnt or has dark residue on it , its time to be rebuilt. Either way.. not much else goes wrong with them that will affect forward only.. You can drain and remove that little oil pan the reverser has and see whats in there..But my guess is its time for it to come out..The reverser case is also the rear engine mount.. so if you do it yourself, plan accordingly..
wildfiretech
10-11-2007 10:45:32
 Re: JD 310C backhoe slow to engage forward in reply to Jonathan in MA, 10-07-2007 17:15:53
Thanks for the info.....
The fluid was relativly clean and did have a funny smell to it. One other thing, the fluid level was about 4 inches above the full mark. Can this have an effect on the darn thing? I priced a new one (no labor) @ about $4,500.00 ouch!!
