4030Jd
smileykeith
10-07-2007 12:10:58
There is a 1977 4030 JD coming up on a auction What Hp. and what are they worth Rear tires are due to be replaced Thanks
smileykeith
10-07-2007 18:47:11
 Re: 4030Jd in reply to smileykeith, 10-07-2007 12:10:58
It has a cab no A/C Diesel Scyncro range 38" rear tires that are in need of replaceing as it has a lot of highway use old County mowing tractor
JMS/MN
10-07-2007 14:10:02
I believe they were 90 pto hp. Weren't they available in gas or diesel- last gassers JD made?. AC was not standard in the SG cab. Also check rear tire size- 34, 38 inch?
95CS
10-07-2007 18:15:35
 Re: 4030Jd in reply to JMS/MN, 10-07-2007 14:10:02
80 horsepower 329 diesel engine. 220-odd 4030's built in 1973 model year with gasoline engines, 1974 and up were diesel-only. Syncro-Range, Quad-Range, or Creeper transmissions.
2cylfarmer
10-07-2007 13:45:47
Need more info. Cab? Condition? Hours?
