46 B oil pump
patsdeere
10-07-2007 00:21:35
I took out the pump to get all the goop out of it and hit a small road block. I am trying to take the pump shaft out of the screen so I can pull the screen off. Problem is that I can"t get the gear off the one end or the square thing off the other end. I assume the square thing comes off, but maybe not. Additionally I can"t seem to get the screen to lift up. I took the wire off and took out the 2 fittings that would hold it in place. Any ideas on an easy way to get it off?
Thanks for all the help.
Mike M
10-07-2007 05:20:07
 Re: 46 B oil pump in reply to patsdeere, 10-07-2007 00:21:35
I have done those many times. The gear is pressed on the shaft so no need to mess with it.The drive coupling is to come off but they do tend to get stuck. It should tap off with a hammer and punch working on opposite sides as you go.File the burrs off the end then pull the shaft and gear out. To get the screen up off remove the wire that locks it in the groove. I then use those pocket screwdrivers you get from places as give aways. It may even help if the end is bent some from prying something else. LOL CAREFULLY work it in and up under the edge of the screen as you kinda lift up on the screen and work your way around and it will come up off. When installing you work the screen back on then take the round shank of that screwdriver and CAREFULLY use it to push the screen back into it's locking groove and then put a new wire back on it. If you happen to poke a hole in it or if it allready has one I have soldered them up before.
