JD3020 DIESEL ? WIL IT PULL A JD ROUND BALER
???HELP
10-06-2007 18:58:01
WILL A JD 3020 DIESEL PULL A ROUND BALER JD ONE ?
RobMD
10-06-2007 19:05:13
 Re: JD3020 DIESEL ? WIL IT PULL A JD ROUND BALER in reply to ???HELP, 10-06-2007 18:58:01
Oh yeah.
Might want to put some ballast in the tires so your 2000 pound bale and 2000 pound baler doesn't push you down the hill.
10-06-2007 19:24:40
 Re: JD3020 DIESEL ? WIL IT PULL A JD ROUND BALER in reply to RobMD, 10-06-2007 19:05:13
PLUS I HAVE WEIGHTS ON THE FRONT AND ?? SO DO I STILL NEED THE BALLAST ? HOW MUCH OF STRESS DO YOU THINK IT WOULD BE ON IT
RobMD
10-06-2007 19:49:35
 Re: JD3020 DIESEL ? WIL IT PULL A JD ROUND BALER in reply to ???, 10-06-2007 19:24:40
If you don't have hills, then don't worry about the ballast. Your driveline and everything will be OKAY. Just run it in 3rd or 4th gear. You will find out what gear you need.
10-06-2007 19:21:09
WHAT DOWN THE HILL WE DON'T HAVE HILLS WHERE I LIVE IN TEXAS ONLY FLAT FLAT LAND AND SURE ABOUT THE HP AND EVERYTHING ON THE PTO AND STUFF LIKE THAT ? WHAT GEAR SHOULD I RUN IT IN I HAVE 1-8 GEARS USUALLY SOLID NICE WINDROWS
msb
10-06-2007 19:41:13
 Re: JD3020 DIESEL ? WIL IT PULL A JD ROUND BALER in reply to ???, 10-06-2007 19:21:09
500 series baler? 3020 should handle it fine. Probably 3rd gear.
