620 loses power
P Schmitz
10-06-2007 18:49:28
Hi,
I have been reading posts in an attempt to help my dad trouble shoot a problem with his old 620. We live in Saskatchewan, Canada. The tractor will start and run normally for about a 1/2 hour under load and then will lose power over the next ten minutes. As the tractor loses power you can keep it running by pulling out the choke but it will eventually die. If you let it cool down for an hour you can again get the same 1/2 hour out of it again. We have replaced plugs and wires.
We have replaced the condenser and coil and points. We have established that we have good fuel flow and have just had the carb rebuilt. It had a lot of rust in it and we thought that a carb kit and a good cleaning would solve our problem but the tractor behaves exactly the same....it dies with in a half hour.
We haven't replaced the rubber seal on the automatic fuel shut off. I have read a few posts about people with a similar problem but no one posts back on how they solved the problem.
Some posts suggest to check the intake and make sure the intake is set to the cold position....it is. Did anyone trace the problem down to air cleaner restrictions?
Did anyone trace the problem down to intake manifold air leak when the tractor is warm.
Any thoughts or advice would be welcome
Paul Schmitz
11-02-2007 09:35:08
 Re: 620 loses power in reply to P Schmitz, 10-06-2007 18:49:28
Just an update.
The 620 runs great again.
We traced the problem down to rust and crud in the stem area of the fuel shut off valve. Thanks to Kent Peterson for the help! Posted by Kent Petersen on October 06, 2007 at 19:42:59 from (71.38.30.75):
CLW
10-07-2007 07:09:02
Just a shot in the dark but is the fuel cap vent plugged? My 630 oil cup was overfilled from rain and would loose power, but it would do it much sooner then 30 min. Still worth a check.
buickanddeere
10-07-2007 06:58:58
Odds are the bottom of the fuel tank is covered in rust/goo. As the engine run the sediment bowl screen gradually plugs tight. A previously stated.The entire aircleaner/hoses/pipework/casting need to be dissembled, mesh removed & washed. The fuel tank will require removal and a couple of dozen 1/2",5/8" or 3/4" nuts thrown into the tank with some hot soapy water. Jack a tractor's rear tires off the floor. And strap down the fuel tank to the side of a tire. Tumble the dirt loose in forward,reverse an re-fasten the tank a 1/4 turn over a few times. Don't waste your time squirting a high pressure washer in the fuel filler and draining out the tanks bottom sediment bowl port. You can't get at 9/10 of the tank.
MSD
10-06-2007 21:49:57
Check the air cleaner-not just the bowl. I bought a 730 LP that did the same thing. Found out the air cleaner inlet was clogged just about solid with mud dobber nests. Don't know if you have them there but it could still be restricted enough.
Kent Petersen
10-06-2007 19:42:59
I would remove the fuel shut off valve mark the parts so you can assy the same as they were replace the two diaframs disasamble the valve and replace the rubber washer on the stem clean everthing in side do not lose the pin that goes between the diafs it is common the find rust and crud in the stem area also check the tank out let lol Kent
Paul Schmitz
11-02-2007 09:33:25
 Re: 620 loses power in reply to Kent Petersen, 10-06-2007 19:42:59
Just an update.
