How to set main jet on 2020 with tsx905 carb
Kent in KC
10-06-2007 16:23:18
I put an overhaul kit in my carb and it ran fine for a while. Then it got to where it wouldn't run at high speed unless you eased the throttle forward slowly. It is belching black smoke.
It has the fuel cutoff solenoid but it is not (and was not) connected. Should I remove the solenoid? If so, what should I put in its place?
How do I set the jet and where, exactly is the jet)? Sorry for being so dense but I'm not familar with this carb. Love my 2020 though, sweet sounding engine.
Thanks, fellas.
KeKent in KC
10-07-2007 06:36:24
 Re: How to set main jet on 2020 with tsx905 carb in reply to Kent in KC, 10-06-2007 16:23:18
Thanks guys. Gerald, I already cleaned and lubed the centrifigual weights, no change. MSB, where is the jet you mention adjusting? Aside from the solenoid I have a drain plug on the bottom of the carb, a slotted plug forward of that and the fuel air mix screw on top. Thanks.
Gerald J.
10-06-2007 21:13:31
On Deere gas tractors the solenoid moves the high speed needle, closes it to stop the engine from dieseling. If its not wired, its probably been cut off so you are runing full rich. When its working the high speed adjustment is the small screw on the end opposite the solenoid mounting. Almost takes a jeweler's screwdriver to turn it.
Gerald J.
msb
10-06-2007 19:34:54
If you have to ease the throttle, chances are the centrifugal timing advance in the distributor needs some cleaning up and lubrication.Remove the distributor cap and rotor and put a drop or two of new engine oil in the center of the distributor shaft.Then remove the distributor points plate and clean up any rust,etc. Then lightly lubricate the mechanism under the plate.White grease is the lubrication of choice here.Turn the top of the distributor shaft and you will see how it works.It needs to turn freely. Be sure to check to see the springs are still hooked up.The centrifugal force has to overcome the springs. The combination sets the timing advance curve which is important for rapid acceleration.
The solenoid was put on the tractor for one reason--to stop dieseling when shutting the engine off. Idling the engine for 3 minutes will do about the same as using the solenoid. No need to remove it. With the engine warmed up and running at wide open throttle,SLOWLY screw the jet in until the engine starts to lose RPMs. Then SLOWLY open the jet until the engine starts to run rich. Its usually about 1 1/2 turns from starving until running rich.Whatever the number of turns, split the difference. Do this procedure two or three times to be sure you have the right setting.Its not rocket science.lol,bob
