'52 AR starter trouble
Dean Lydey
10-06-2007 14:40:05
I just brought a '52 AR at auction. The tractor runs great and so far so good. Today when I go to turn the key and push the starter button I get a moan or whine from the starter. The starter isn't turning over the motor, just this sound. Maybe a solenoid perhaps. I know I'm not describing this well. I have this with a '50 B I have. I hit the starter button a few times and eventually it "catches" and the motor turns over and starts. I hoped I could continue to do this with the AR and eventually get it started, but the situation worsened. After about 4 tries to try to get the starter to "catch", I finally tried and got nothing. Pushing the starter button got nothing from the tractor that I could detect. The moan/whine stopped and nothing was happening. The battery box is right on the dash of the AR so I opened this and pushed the starter button again. Still nothing but a few sparks on the positive terminal on the battery. That can't be good. I'm looking for ideas. Could this be electrical or do I have a starter/solenoid issue thats giving me the sparks on the batery terminal.
Thanks for any help,
Dean
RobMD
10-06-2007 20:01:59
 Re: '52 AR starter trouble in reply to Dean Lydey, 10-06-2007 14:40:05
no "solenoid" of ANY KIND on both of your tractors. Instead, there are contact switches on the starter in which you press the engage, the contacts close and provide the current for starting.
You need to pull your starters and replace these switches which are available at deere.
Dean Lydey
10-07-2007 05:12:51
 Re: '52 AR starter trouble in reply to RobMD, 10-06-2007 20:01:59
THank you. I'll yank it after church.
LenND
10-06-2007 14:48:13
If you got sparks at the battery post you don't have a good connection. Take the cables off and clean them good. The whining noise could be your starter isn't connecting with the fly wheel, maybe the starter should be removed and cleaned and inspected.
