'40s John Deere MI
Montana homeste
10-06-2007 12:18:41
I recently Traded a '63 Dodge M37 for a 55 International 4x4 and a 45ish John Deere MI. I have heard the "I" model of this tractor is very rare. It has been retrofitted with a loader and came with a back blade. It runs (sounds like on only one cylinder, though) and the Idler pulley seized up when I hooked up the generator. Other than that it seems to be in fair shape.
My questions are:
1) How can I verify it is actually an "I"
2) I had planned to use it around the homestead, but would it make more sense to trade it (for a more common model in better shape)to someone for professional restoration.
3) Where can I find a rebuilt/OS idler pulley and rings for the bad cylinder?
Thanks MH
Dave H
10-07-2007 05:59:19
 Re: '40s John Deere MI in reply to Montana homesteader, 10-06-2007 12:18:41
I wold pull the plug wires one at a time and see if that tells you if one cyl is dead. With all that weight it is a sonder that is pulled itself if running on one.
If on one and if that is just a Dubuque quirk instead of needing something, it will probably be the rear plug that has fouled out.
Maark
10-06-2007 15:49:17
You may try new plugs. The Dubuque engines seem to foul plugs very easy.
Montana homesteader
10-06-2007 18:44:29
 Re: '40s John Deere MI in reply to Maark, 10-06-2007 15:49:17
Thanks, I check.
Montana homesteader
10-06-2007 13:21:26
Thanks Brandon. I'll check it when I get home. I remember seeing that tag it is a little faded though.
Are all the MI's yellow (mine is except for a green replacement fuel tank)
I drove it home it is definitely a fun little machine.
105EB
10-06-2007 17:29:39
 Re: '40s John Deere MI in reply to Montana homesteader, 10-06-2007 13:21:26
The vast majority of the MI tractors were painted industrial yellow---a few green ones have shown up. They only made 1032 of them,which makes them more rare than a "330". They are undervalued right now, and keeping one will pay dividends in the future. Best of luck to you, they are sweet little tractors.
two cylinders saves gas
10-06-2007 17:59:13
 Re: '40s John Deere MI in reply to 105EB, 10-06-2007 17:29:39
That is saying something since iv'e seen 30,000 dollar 330's .
Montana homesteader
10-06-2007 19:48:46
 Re: '40s John Deere MI in reply to two cylinders saves gas, 10-06-2007 17:59:13
"That is saying something since iv'e seen 30,000 dollar 330's ."
:O If it is worth anything near that I could trade up to a larger model with more implements. :)
105EB
10-07-2007 18:19:29
 Re: '40s John Deere MI in reply to Montana homesteader, 10-06-2007 19:48:46
Don't count your chickens just yet. 330's will always be more popular because they were the last of their kind. MI's are undervalued, but don't ever expect to get $30K or anywhere close to that for one.
WeirdDeere
10-06-2007 12:58:04
Look at the tag on the dash (right under the ignition/light switch). It should say model M or MI. MI's were built from 1950-'52 by the way.
Picture of tag:
If it's in good shape, and you don't ABUSE it, I think you could use it for work. They were made for it! That's my opinion anyway.
A small webpage on the MI: here
Brandon
Montana homesteader
10-07-2007 16:14:52
 Re: '40s John Deere MI in reply to WeirdDeere, 10-06-2007 12:58:04
I found the tag. It does say MI and The serial # is 1010* So I guess it is a 1950 (thanks for the helpful link).
Could you guys give me a lead on where would be a good place to put it up for trade. I don"t need a collectors just a good reliable (larger would be nice) work horse. What would be a good trade? I want to stay with a Deere, gas, with loader bucket and back blade, haying implements a ++.
It is complete but rough. Runs but with the before mentioned problems. Do you think I"m thinking straight, that it could be traded for what I mentioned?
