JD 2840 PTO
SHORTORDER
10-06-2007 08:07:17
I'm having a hard time repairing my JD 2840 PTO. I have been inside the tractor several times now and still not working. The first problem was that the PTO came apart. I put it back together and the PTO work but the FEL would not work. Went back in and found a broken seal. Replaced the seal and put it back together. Same problem the FEL would not work. Went back in and found a cut o-ring. Replaced the o-ring and put it back together. This time the same thing the FEL would not work. Found a bent pipe, replace it and back together. This time the PTO would not work at all. When back in and found another seal broke. Repaired and back together. This time the PTO worked until the oil got hot. The FEL works fine. Anyone got a ideal what the problem might be other then me. This is a first time for me, doing any type major repair. I'm still in the learing mode. Is there away to check if it is working before you put it back together. I know already I will have to go back in. Any help would be greatly appreciated.
Tx Jim
10-08-2007 03:50:27
 Re: JD 2840 PTO in reply to Mike M, 10-06-2007 08:07:17
Shortorder,try isolating(disconecting) the FEL. Certain 2 spool valve are convertible from open to closed-center and those valves can blow an internal quad-ring creating a problem similiar to yours. Look inside hyd filler hole with engine running and 3pt raised. You should see no spraying or misting oil. What tech manual are you using? One just has to love diagnosing a closed-center hyd problem!! Tx Jim
buickanddeere
10-07-2007 07:04:23
 Re: JD 2840 PTO in reply to SHORTORDER, 10-06-2007 08:07:17
Sounds like a pile of rework by repairing one item and breaking another while in there? Do you have the service manual and a pressure gauge set to measure trans oil pressure? There are several relief valves and oil diversion valves that can get stuck with a tiny bit of dirt/grit. We are assuming the oil inlet screen is clean? Ever find anything in the screen or filters?
SHORTORDER
10-07-2007 11:10:53
 Re: JD 2840 PTO in reply to buickanddeere, 10-07-2007 07:04:23
I would have to say (yes) to your questions. The service manual does not give much info on how to check it all out. I have checked the pressure in three different place and there all good. The Hi/Lo works fine and the 3 point also works. Have not found any stuff in the filter system it appears okay. I have seprated it once again and can not find any problem. I took the PTO Clutch apart, and everything appeared to be good. I replaced the o-ring and ring seal again, since I had them onhand.
Tx Jim
10-07-2007 04:03:04
 Re: JD 2840 PTO in reply to Matt L, 10-06-2007 08:07:17
I think the "hot oil" would indicate a high pressure not low(trans pump) leak. Does 3 pt work properly? Where does your FEL tie into the hyd's? Does hyd operation remain the same when shifting hyd hi-lo? Tx Jim
SHORTORDER
10-07-2007 11:17:39
 Re: JD 2840 PTO in reply to Tx Jim, 10-07-2007 04:03:04
The 3 point works fine. The FEL is tied in at the transmission filter. Everything works fine in the HI or LO range. Shifting between the two does not effect anything. I agree, that it is possibly in the high pressure system but have no ideal how to check it out. The service manuals just says find problem and fix. Someone with a brain figured out that statement.
