JD 2040 lift judder
smithsms
10-06-2007 02:57:50
My JD 2040 judders a little when raising the hyd arms does it the same warm or cold fluid level is ok and the steering and brakes are all ok. The hydraulics are strong even when hot.
Any ideas your input would be apreciated.
She is a UK tractor 1986
Tx Jim
10-08-2007 03:58:28
 Re: JD 2040 lift judder in reply to OhioTractorGuy, 10-06-2007 02:57:50
If tractor is equipped with SCV(remote pulg-in's aka wet lines) that is easiest place. If not can be checked at frt hyd pump. Tx Jim
Tx Jim
10-06-2007 04:31:09
 Re: JD 2040 lift judder in reply to Pitalplace, 10-06-2007 02:57:50
Have you changed hyd filter and cleaned sump screen? You also need to check stand-by pressure and it needs to be 2250 psi. Tx Jim
smithsms
10-07-2007 07:38:58
 Re: JD 2040 lift judder in reply to Tx Jim, 10-06-2007 04:31:09
Hi, where would you check the stand by pressure, thanks
