#9 Sickle Bar Mower???
Bob in Ga
10-05-2007 14:27:45
There is a used equipment dealer near me that has a #9 mower for sale. I know nothing about these machines other than I could use a mower to mow some banks that I have and do some general tidying up around the place. Were these generally reliable mowers? Is there anyone out there who still uses one of them. Since he has two of them on the lot should I negotiate a price for both and use one as a parts machine? Any comments would be appreciated.
ErnieDD
10-05-2007 15:53:29
 Re: #9 Sickle Bar Mower??? in reply to Bob in Ga, 10-05-2007 14:27:45
What tractor you going to use with it? We used fords, and it was either up or down, no inbetween. Only mattered when you were finishing out a field. As the other poster said, the knives and ledger blades need to be in good shape.
Broke slip clutch internal, must have been a casting defect. I would not bother with a parts machine. Only broke knives and pitman stick.
tim-in-nc
10-05-2007 15:33:17
Well a #9 mower is a pitman drive sickle. Not really sure it will do what you want it to do. You said that you wanted to cut some banks. How much of an angle are you thinking of cutting? I think the mower (like most pitman mowers) can only cut about 15 or so degrees off of horzonital. A belt drive sickle mower like a ford 515, later new holland and massey mowers will cut to near vertical and about 60 degrees below horzonital. Hate to see someone buy something that won"t do what they want it to do.
Tim
RobMD
10-05-2007 14:52:10
number 9 mowers fit the best on two cylinder tractors. Yes, they were generally good mowers, but the trick to ANY sickle bar mower is how good your cutting bar is. If it's all rusted up and dull, you're gonna need new guards and a sharp section.
