JD 1630 with Hydraulic Loss
S R C
10-05-2007 13:59:11
We have a JD 1630 that when you first start-it, the hydraulics and powersteering work fine but after about 10 minutes, there is no steering or hydraulics available. I can't seem to find a good place to tap into the transmission pump line to see what kind of flow and pressure the transmission pump is putting out.
Any suggestions/help that anyone can offer would be much appreciated!
Thank-you,
SRC
Tx Jim
10-06-2007 04:39:02
 Re: JD 1630 with Hydraulic Loss in reply to Andy Motteberg, 10-05-2007 13:59:11
More than likely you have an internal high pressure leak. The rockshaft valves or steering valve are a good place to check. If tractor has a frt loader with indepedent valve that is another place to suspect. Tx Jim
