1947 B
craig reavley
10-05-2007 08:29:30
I just bought a 1947 B to restore, It is a late styled with the stamped steel frame. For some reason it runs twice as fast as my 1947 A when set wide open. I know it is a smaller engine but why would it run that much faster?
third party image
P Browning
10-05-2007 18:39:18
 Re: 1947 B in reply to craig reavley, 10-05-2007 08:29:30
Craig -- I found the spec's for your JD-B tractor -- in Field Service Bulletin 167-S, 2/15/1950. Pressed Steel frame tells me it is serial number 201000 or above, and for "B" tractors 201000-up, we have the following engine RPM data: Fast Idle is 1370 and Load is 1250.
The data I gave earlier for "A" tractors is good for all "A" tractors although some Deere data sources may list Fast idle at 1080 in place of 1075, but Load RPM is 975 for all "A" tractors. (PatB)
P Browning
10-05-2007 15:05:25
Craig -- From Field Service Bulletin 118-S dated 2-15-41, we have the following engine speed data:
Model A: Fast Idle = 1075, Load = 975
Model B: Fast Idle = 1310, Load = 1150
These data points hold for all series A & B tractors through the opening of 1941 production, and so far as I know -- they held at least through the PAN SEAT era of these tractors, and perhaps beyond. (PatB)
Mike M
10-05-2007 15:59:53
 Re: 1947 B in reply to P Browning, 10-05-2007 15:05:25
This thread just proves the value of having the books on hand. I have them ,but they are about 4 miles away ! This way you don't need to remember every little detail and spec. all you need to remember is where you put the book.
I can tell you from first hand experience on a dyno just a year or two ago that on a model A that 100 RPM is unbelievable how much differance it can make in HP and the way it performs. So I stress to this fellow again to CHECK THEM BOTH ! and set them if needed.
Len Bull in NC
10-05-2007 12:33:04
Having worked with both many years ago (I own a 50 A still) the difference in RPM's bothers some folks. Especially those who are used to only B's. They think that the A (or G) is just going to die..but listening to and watching one of them dig in and pull or hit a big wad of chopped silage corn on a blower without plugging the pipe will cure that concern fast! The value of that big flywheel!! But checking the RPM's is certainly worthwhile.
RobMD
10-05-2007 12:02:20
so the B can get the horsepower. Its engine is small enough to run that fast
running a big bore engine really fast will tend to get a mind of its own and throw a rod out to china.
Look at it this way, a japanese rice bike has pistons of about 2 and a quarter inches in diameter, with a really short stroke. It is capable of running up to 12,000 rpms safely.
Stan - Florida
10-05-2007 11:17:40
The A should be at 975 rpm and the B should be at 1250.
Stan
Mike M
10-05-2007 11:30:51
 Re: 1947 B in reply to Stan - Florida, 10-05-2007 11:17:40
That sounds like the rated RPM for load so the settings just sitting running wide open ( fast idle )will be a little more.
Stan - Florida
10-05-2007 13:21:45
 Re: 1947 B in reply to Mike M, 10-05-2007 11:30:51
Mike,
I'm sure you're right. My reference is a brochure from 1947 that gives the numbers I mentioned. It does not differentiate between load and fast idle speeds. My '41 B is rated at 1150 rpm.
Stan
Mike M
10-05-2007 09:53:39
It is a smaller engine and as such will be set to run faster than your A. I can't remember the exact figures off the top of my head. But it shouldn't be twice. It would be well worth the time to check the RPM of both of them as the A may be too slow and the B too fast. Easy to adjust at the stop bolt at the bottom of the steering column.
