1936 D
Bobl1958
10-05-2007 07:16:06
Does anyone know how much water the radiator on a '36 D holds. A friend just bought one with only water in it and he wants to drain it and put a mix in. He has the original owners manual, but it doesn't say. Anyone know for sure. I'm thinking about 10 gals, but at the price of antifreeze, he hates to buy too much. Thanks-Bob
Bobl1958
10-05-2007 18:21:48
 Re: 1936 D in reply to Bobl1958, 10-05-2007 07:16:06
Thanks for your replies. The tractor is in the country and i believe the guy wants to buy 50/50 mix and haul it out there to the tractor. I was hoping to get close enough he didn't buy too much. Thanks again for your replies. Bob
Duane Larson
10-05-2007 09:31:01
Bobl1958,
Field Service Bulletin 101 (September '39) gives 10 gal as the cooling system capacity. The capacity went to 14 gal at 143800. But measuring it as suggested by others is a good idea.
RobMD
10-05-2007 08:27:24
measure what you take out by using a 5 gallon bucket. Then pour a 50-50 mix of antifreeze and dump it back in.
Buster
10-05-2007 08:01:10
It is either 13 or 14 gallons
Mike M
10-05-2007 07:48:51
Here's a thought ? Measure what you drain out ?
Use a 50/50 mix and be sure to mix it up in a bucket BEFORE you dump it in this way you are sure it is mixed.
