Have a book for JD Model FB Drill? 13 hole-7 in spacing
Too Far Gone
10-04-2007 13:44:56
If anyone could help I'd appreciate it.Im sowing wheat soon,and Im without a book to tell where to set it for 2 bu. per acre rate.I borrowed the drill,and he lost the book.Thanks
jubilee johnny
10-04-2007 16:03:57
 Re: Have a book for JD Model FB Drill? 13 hole-7 in spacing in reply to Too Far Gone, 10-04-2007 13:44:56
I have a book but it calls for the weight of the wheat seed rather than the # of bushels. Also you need to know the tire size of the drill.The example in the book says that if you had 7.50x15 in tires and you wanted to drill 82lbs per acre you would set it at notch 16 which would be 84 lbs to compensate for the tire size. I don"t know that much about drilling wheat, but I do have the book if you can get lbs.
Too Far Gone
10-04-2007 16:26:50
 Re: Have a book for JD Model FB Drill? 13 hole-7 in spacing in reply to jubilee johnny, 10-04-2007 16:03:57
Ive got 15 inch tires,and 2 bushel is 120 lbs.Everybody shoots for 100 to 120 lbs around here.Thanks
jubilee johnny
10-05-2007 08:41:31
 Re: Have a book for JD Model FB Drill? 13 hole-7 in spacing in reply to Too Far Gone, 10-04-2007 16:26:50
I was wrong. The correction factor for tire size was for 16 inch rather than 15 as I stated earlier. I'm no expert but it looks like you would put it on the seed index notches between 20 and 24. Someone else with more experience will know.
Too Far Gone
10-05-2007 08:45:06
 Re: Have a book for JD Model FB Drill? 13 hole-7 in spacing in reply to jubilee johnny, 10-05-2007 08:41:31
Thanks for the help
