Compression Test - JD-A
David Self
10-04-2007 09:27:57
Need to know the compression test for an Unstyled John Deere A (1935) model year.
Thanks, David
Duane Larson
10-04-2007 11:24:36
 Re: Compression Test - JD-A in reply to David Self, 10-04-2007 09:27:57
David,
Field Service Bulletin 212 (Feb '54) gives 75 psi measured at 975 rpm. So, to do this you need to belt your A up to another tractor, spin it at 975 rpm, and you should measure 75 psi.
That is for all-fuel pistons, as built. If you have gas pistons, high compression head, etc. the number for a gas engine is 110 psi.
David Self
10-16-2007 19:16:12
 Re: Compression Test - JD-A in reply to Duane Larson, 10-04-2007 11:24:36
Hey Thanks alot for the info. - I got 30#'s on both sides by hand cranking the flywheel and also cranking on one cylinder while the compression tester was plugged in to the other side. Same results.
