140 wt Trans. oil
Dave Forbush
10-04-2007 08:40:49
Slowly restoring a 39 JD A. Have an elementary question for you guys about the trans/rear end oil. The book calls for 140 wt. The large local oil supplier says that there is no such thing. Offered up 85-140. I almost bought it but thought I would check back with you.
Thanks!
jgc
10-07-2007 06:36:04
 Re: 140 wt Trans. oil in reply to Dave Forbush, 10-04-2007 08:40:49
I buy 140 wt from a local specialty lube place.
I was told to use 140 becuase these old girls leak less with the thicker oil.
My lube guy can get 460 wt gear oil!
He has been asked for 600 wt. but hasn't found a source for 600 wt
CalJim
10-04-2007 21:55:04
If it's going to be a trailer queen then 90 wt. is fine. CalJim
Dave Forbush
10-05-2007 11:30:32
 Re: 140 wt Trans. oil in reply to CalJim, 10-04-2007 21:55:04
P.S. CalJim, I think, it's a boy. I'm new at this and not good at sexing them yet but when I put the little JD H in the barn I could detect a bit of excitement.
Dave Forbush
10-05-2007 05:30:41
Thanks, CalJim.
Dave H
10-04-2007 14:56:16
Dave
If ya got any farm suply stores around give them a call. That is where it is localy here
Dave Forbush
10-07-2007 12:29:51
 Re: 140 wt Trans. oil in reply to Dave H, 10-04-2007 14:56:16
Thanks! It could be too easy. I'll give TSC a call.
Dave
wilamayb
10-04-2007 08:47:04
Your supplier has not looked hard enough. Tell him you need GL1-140 gear lube. He will most likley have to special order it. The 85-140 will work, but the GL1-140 will certainly be quieter.
I've gotten some from my local Exxon distributor. There also used to be a seller of Gl1-140 in greenmagazine, but I'm not sure if I've seen the ad latley.
Dave Forbush
10-04-2007 08:50:53
 Re: 140 wt Trans. oil in reply to wilamayb, 10-04-2007 08:47:04
Thanks.
Amazing how complicated simple things can get. I'll keep checking around.
Dave
John Tigert
10-04-2007 17:36:16
 Re: 140 wt Trans. oil in reply to Dave Forbush, 10-04-2007 08:50:53
Contact Larry Wolf, Clearwater, KS. Ph 620-545-7628
he sells the GL-1 140w for $48.95 plus shipping for a 5 gal pail.
Dave Forbush
10-04-2007 19:05:16
 Re: 140 wt Trans. oil in reply to John Tigert, 10-04-2007 17:36:16
Thanks, John. That's a big help.
