Electrical Question
Osage
10-04-2007 06:17:42
According to everything I've read originally the 1010's all had a Generator/Voltage Regulator 12v positive ground system. A previous owner changed mine to an Alternator 12v Negative grounded configuration.
My question is this: Should the correct coil be an external or internal resistor type? The coil has a 12v positive wire from the ignition switch to the +positive side and a wire from the -negative side to the distributor(no visible resistor is present).
For what its worth, the tractor starts and runs good, however the coil seems to get excessively hot. The current coil though not original is an external resistor type.
Thanks,
Osage
sparepartsTN
10-06-2007 12:44:36
 Re: Electrical Question in reply to Osage, 10-04-2007 06:17:42
Osage,
According to my JD SM-2034 Service Manual (1010 Series Crawler Tractors), same engines, you are correct. They shipped from the factory with 12 volt positive ground with a generator. The wire from the "I" connection on the ignition switch goes directly to the coil with no resistor ect. in line, and a wire from the coil to the distributor. The book states " always use a coil the same make as the distributor ". That said, my 1965 had been converted to 12 volt neg. with an alternator, always worked fine with a standard 12 volt coil, as already mentioned buy a 12 volt coil and you should not have any problems. If you have other questions that I can help with, my e-mail is: [email protected], and my manual is handy.
Good luck, Warren
buickanddeere
10-04-2007 13:21:44
It's not "ground" , it's "chassis" return on most mobile DC equipment. A pile of electrical problems would go away if copper wire was ran as returns rather than using the chassis on mobile DC equipment. "Ground" is the metal enclosures etc on AC equipment."Neutral" is something different again when it appears on some AC equipment. What is the current through the coil's primary circuit? Which battery terminal is connected to chassis?
John T
10-04-2007 07:07:15
On a 12 volt tractor THAT HAS NO EXTERNAL BALLAST NOR AN EXTERNAL THERMISTOR (resistor that increases value when warmed up) WIRE LINK
You need a full true 12 volt rated coil, some people refer to them (not actually correct) as internally ballasted. Such a coil may be labeled "12 volts" or "12 volts NOT for use with external ballast"
HOWEVER if the coil is in reality a 6 volt coil which may be labeled "6 volts" or even "12 volts for use with external ballast resistor" THEN YES YOU NEED EITHER AN EXTERNAL VOLTAGE DROPPING (12 to 6) DISCRETE BALLAST RESISTOR or else a Thermistor wire link feeding the coil whose resistance increases once its warmed up
THAT BEING SAID, if the coil runs so hot you cant barely hold your hand on it, IT SOUNDS LIKE ITS A 6 VOLT COIL and requires EITHER an external ballast resistor around (1.5 to 1.85 ohms) or else the correct thermistor or thermistor wiring link ahead of the coil so after it starts (on full 12 volts) the wire gets hot and its resistance increases so its like an external ballast dropping 6 volts leaving 6 on the coil so it dont overheat.
BOTTOM LINE if the coil runs too hot Id either add a garden variety voltage dropping ballast resistor in series after the switch but before the coil OR ELSE EASIER to just use a full true 12 volt rated coil (NO ballast required) n be done with it.
A 6 volt coil will have around 1.5 ohms primary resistance as measured between its lil + and - terminals while a 12 volt coil has more like 2.5 to 3.5 ohms. Yes, at neg ground its lil - wires to the distributor.
YOU NEED TO DETERMINE IF YOUR COIL IS A 6 OR 12 VOLT AND IF A 6, ADD BALLAST (or Thermistor wire link) OR GET A FULL TRUE 12 VOLT COIL NO BALLAST REQUIRED.
Got it?????
John T
Bob
10-04-2007 06:58:43
Since parts of the electrical system have already been modified, who's to say what the "correct" coil is!
If you can, measure the primary ignition circuit current, switch "ON", points closed, engine NOT running. You are looking to see about 3 Amps, or a little more NOT over 4 Amps.
If current is too high, you can add a simple automotive ballast resistor, or swap to a "needs NO external resistor" coil.
A lot of guys are using the NAPA IC-14SB coil, which costs less than $20.00, and needs NO resistor!
John T
10-04-2007 07:09:58
 Re: Electrical Question in reply to Bob, 10-04-2007 06:58:43
Bob, Im NOT a New Generation guy but think/wonder some of those small Deeres used the thermistor wire link ballast system versus a discrete bathtub style ballast, you know????? ???
John T
Gerald J.
10-04-2007 08:14:56
 Re: Electrical Question in reply to John T, 10-04-2007 07:09:58
In my '68 4020 the resistor was mounted on the back of the ignition switch. And shorted out by the auxiliary contact on the starter solenoid. Some used a piece of insulated iron wire too. Anyway mine had been rewired with a scotchtap and a ceramic block resistor next to the coil. One summer it would start but wouldn't run, had to hot wire it to finish the hay. That scotchtap had gone open. Now its wired differently where the scotchtap was and seems reliable.
Since the 1010 is a Dubuque product, I can't say its wiring was comparable to the 4020, a Waterloo product. The early new generation tractors from Dubuque didn't match the quality of those from Waterloo.
Gerald J.
