Oil Pressure on a '41 B in PSI
B Owner
10-04-2007 04:15:01
Hello,
My manual says the oil pressure should be between "M" and "H" on the gauge at high idle. Does anyone know how many PSI this translates to?
B Owner
P Browning
10-04-2007 05:48:03
 Re: Oil Pressure on a '41 B in PSI in reply to B Owner, 10-04-2007 04:15:01
In accord with Field Service Bulletin 118-S, Feb 15, 1941, oil pressure should remain between 10 and 15 PSI. I hope this helps. (PatB)
Duane Larson
10-04-2007 05:47:24
B Owner,
Field Service Bulletin 118 (Feb 1941) gives 10-15 psi for the B, measured at the gauge.
BMAN
10-04-2007 05:47:11
I believe M is supposed to be 10 lbs and H is 15lbs.
johndeereman
10-04-2007 05:20:49
i believe its 18 psi some where there abouts pressure aint as crutial as volume
P Browning
10-04-2007 05:49:11
 Re: Oil Pressure on a '41 B in PSI in reply to johndeereman, 10-04-2007 05:20:49
Volume is a function of pressure. (PatB)
