Carb Bowl Difference
Ron in CO
10-31-2003 17:22:38
What is the difference between DLT7 and DLT13 Carb bowls? DLT7 is supposed to be used on the brass carbs, but I can't see any difference between them.
Duane Larson
10-31-2003 19:17:27
 Re: Carb Bowl Difference in reply to Ron in CO, 10-31-2003 17:22:38
Ron,
There are a couple of differences - on most DLT7's there is less "meat" around the hole where the fuel inlet screws in, and the recess for the bowl washer is smaller in diameter (leading to poor fits for many fiber washers in current rebuild kits). The DLT13 was an improvement in that the region around the fuel inlet was beefed up to prevent cracking of the casting between the fuel inlet and the strainer cover. Also, the recess for the washer was increased, allowing a wider fiber washer to be used.
Those are the main differences I have observed over the years of rebuilding.
