4230 Loss of Hydraulics update
R. John Johnson
10-03-2007 06:17:30
The mechanic came out yesterday to look at the tractor. One of the first things he did was pull the shaft Tx Jim mentioned, but that was not the problem. In the end it was a stuck valve letting flow from the trans pump back to the rear end. Valve located on the left side of the transmission behind the filter, under the larger of the two hex plugs.
Oil that came out of the trans filter seemed clear now, which I don't understand. When I caught a sample the other day, it looked contaminated.
The left rear axle seal is going out and the mechanic said the bearings are probably loose/going. If there is play on the axle things could be moving enough to cause wear and cause the original contamination in the axle. I'm going to set up a repair on that with him ASAP.
Thanks for the replies on the original post.
John
Tx Jim
10-04-2007 03:17:22
 Re: 4230 Loss of Hydraulics update in reply to wilamayb, 10-03-2007 06:17:30
Glad you got one problem solved. Tx Jim
mjbrown
10-03-2007 06:40:52
 Re: 4230 Loss of Hydraulics update in reply to R. John Johnson, 10-03-2007 06:17:30
I for one appreciate when people give updates like this so we know the rest of the story and what to look for at home.
Thanks
onefarmer
10-03-2007 09:49:43
 Re: 4230 Loss of Hydraulics update in reply to mjbrown, 10-03-2007 06:40:52
Ditto Thanks for the response!!
