200A cultivator application?
Bob
10-03-2007 00:47:12
I came upon a "200A" tractor-mounted row-crop cultivator that the owner will sell darned cheap.
Anyone know what it fits?
2010?
2-cylinder tractors?
Bob
10-03-2007 18:37:39
 Thanks to all for the help/comments. in reply to Bob, 10-03-2007 00:47:12
wikevin
10-03-2007 09:09:49
 Re: 200A cultivator application? in reply to Bob, 10-03-2007 00:47:12
Most answers are some what right the 200 is a 2 row that wil fit the 2 cyl b - 730 there are a few different frame lengths and 2 different widths. Look at the parts books youll see. Ive had 3 2 row 200s in the last 10 years,(each one difft from the other) both straight shank and spring tooth(what I prefer) If it has the center connecter pcs to fit a B - 530 it will not spread wide enough to fit the A- 730 however the wide frame will fit the narrower tractors, it will just have space on each side in front. Around here(north western WI) they are askig 100 to 200+ for them but when you try to sell one for that good luck. It is also hard to find a complete one with all shields, rear gangs and brackets. When you do youll find the old books dont lie, they are fast mounting and do a great job if you spend some time on your set up. Have Fun
Chances R
10-03-2007 07:15:04
A guy here at work would really like to have one for a unstyled a.
[email protected]
Bob
10-03-2007 19:55:27
 Re: 200A cultivator application? in reply to Chances R, 10-03-2007 07:15:04
I sent you an email. Post back if you don't get it.
Stan - Florida
10-03-2007 05:17:10
A sales brochure from September 1953 says that the 200 (two-row) and 400 (four-row) will fit the 50, 60, 70, A, B and G tractors.
Just guessing, but the frames of the 520, 620 and 720 tractors did not change much (if any) from the 50, 60 and 70, so your 200 could possibly fit those later models as well.
Stan
johns48jdb
10-03-2007 04:09:49
its called a 200abg because thats the models it fits.
J.Schwiebert
10-03-2007 03:01:59
If I remember correctly the 37 B we had at home had a model 200 cultivator.
Tx Jim
10-03-2007 02:58:08
 Re: 200A cultivator application? in reply to low budget, 10-03-2007 00:47:12
I'm relatively sure that a 200A will not fit a 2010 but will fit Waterloo 2 cylinders. Tx Jim
