1967 2510
darrel l steinb
10-02-2007 20:13:52
Tell what you think of a 1967 JD 2510 diesel,syncro-range transmission,wide front end,good sheet metal,new piant,new main bearings & rod bearings,rear tires 75%, need new front tires,hours unknow for $4000.
Paul in WI
10-03-2007 17:49:32
 Re: 1967 2510 in reply to darrel l steinbach, 10-02-2007 20:13:52
$4000 is a really good price if the engine and transmission are good. Make sure there is no antifreeze in the oil. Paul in WI.
Doug in IL
10-03-2007 19:18:08
 Re: 1967 2510 in reply to Paul in WI, 10-03-2007 17:49:32
Paul, I have one that I recently discovered DOES have antifreeze in the oil pan. What am I most probably looking at here. New liners? Or something else?
JDknut
10-04-2007 04:39:14
 Re: 1967 2510 in reply to Doug in IL, 10-03-2007 19:18:08
It could be the head gasket, a leaky oil cooler, or pinholed liners. A pressure test in the cylinders can help diagnose this. On my 2350 MFWD which has a similar design engine, I had antifreeze in the water, and it turned out to be pinholed liners. I caught it in time, so I was able to get away with an inframe. This cost around $3500 to $4000, with pistons, liners, bearings, valve job, etc. A reman engine will likely run around $4500, but you still will have the labor of getting it into the tractor. I hope for your sake it is something simple like an oil cooler, but even a head gasket is better than needing new liners. At any rate, you should run additive in the antifreeze that will prevent electrolysis and cavitation erosion, which is what causes the wet sleeve pitting in the first place. Little bubbles in the coolant pop and blast holes in the liner. Deere dealers sell this additive and I am sure you can get it at other places. It would still be worth it to fix it as a 2510 is one of the most desirable tractors of that size.
Doug in IL
10-04-2007 06:23:08
 Re: 1967 2510 in reply to JDknut, 10-04-2007 04:39:14
I thank you for taking time to reply, JDknut. The oil cooler thing hadn't occurred to me. We are busy with corn harvest now, but will get it in the shop this winter.
JDknut
10-04-2007 09:13:24
 Re: 1967 2510 in reply to Doug in IL, 10-04-2007 06:23:08
well, I wish you luck on that and hope it isn't the liners. I wouldn't run it very much until I had a chance to look at it, as the antifreeze in the oil prevents the lubing ability and you might ruin the crank as well as the bearings, and then that would be at least an extra grand, including labor. Good luck!
Doug in IL
10-04-2007 18:07:29
 Re: 1967 2510 in reply to JDknut, 10-04-2007 09:13:24
No, it hasn't been run at all since I found the antifreeze in the oil. Thanks again.
RobMD
10-03-2007 11:16:59
Go for it. First, look around the wide front for cracks and welds. Try out the clutch. Check that 3 pth doesn't jump up and down. check oil and antifreeze.. none should be mixing!!! Brakes should be even and not grabby or too sloppy.
If you're confident that it's a relatively tight tractor, go for it.
2510's are ~NOT~ associated with the problems of the 2010.
MLD
10-03-2007 05:56:52
I've never had one but always heard they were very good tractors, the bad one was the 2010.
MSM
10-02-2007 23:42:37
The sheet metal,front end and hitch are worth the asking price. They are an all around good tractor.
